Date/Time: Sat, 22 Feb 2025 09:03:12 +0000
Support for apple , will it arrive one day ?
View Count: 1184
[2020-12-18 12:55:19]
GravisHTG - Posts: 306
I am asking because I just swap to M1 Mac and they are Insanely fast ( compare to the 8750h laptop I had ) The only problem is the support of windows program on them. Currently I can use Your software with Crossover with little problems. But I would love to know if you have any plan of going over to apple OS ? And You if you like , you can check with crossover team , they offer a way to port windows program to Mac with full support.
thanks in advance and continue your good work !
Date Time Of Last Edit: 2020-12-18 16:29:17
[2020-12-18 18:03:18]
Well one thing we will be doing is adding support for ARM processors. Not sure if this is all that is needed to solve the compatibility issue.
[2020-12-22 18:02:03]
User800642 - Posts: 3
this paralel option you offer is terrible, we need a native mac app...
[2021-01-31 19:51:16]
bwalks123 - Posts: 122
Any update regarding support for the ARM processors (mac m1 chip)? Would love to run parallels off mac mini m1!
[2021-02-01 13:11:50]
We have the check on this.
