Date/Time: Sun, 23 Feb 2025 09:00:33 +0000
[User Discussion] - Market Depth Historical Graph (MDHG) - Independent Intraday Chart Bar Period
View Count: 760
[2020-12-18 11:20:53]
User287830 - Posts: 9
Is there or is it possible to add a feature for MDHG to be independent of the current intraday chart bar period?
For example: I would like the MDHG from Image 1 a 5 minute chart, to look like the MDHG on Image 2 a 5 sec chart
Therefore, I can trade on a 5 minute chart with the detail and nuance of a 5 sec MDHG on the same chart.
I have also attached a screenshot from Bookmap with 5 min candles to help further illustrate.
Image1 5m: http://www.sierrachart.com/image.php?Image=1608288058127.png
Image2 5sec: http://www.sierrachart.com/image.php?Image=1608287671858.png
Date Time Of Last Edit: 2020-12-18 11:21:15
imageBM.PNG / V - Attached On 2020-12-18 11:19:07 UTC - Size: 469.11 KB - 238 views
[2020-12-18 12:00:35]
User907968 - Posts: 832
You could overlay the 5-min candles onto the 5-sec MDHG chart using - Study/Price Overlay Study - and set the Graph Draw Type of the 5-sec chart to Blank - Graph Draw Types
[2020-12-18 12:34:08]
#2 User907968 Thanks for the suggestion.
The problem is, the studies I want to overlay cannot be done.
Paragraph below is from - Study/Price Overlay Study
The following studies cannot be overlaid from one chart to another with the Study/Price Overlay study:
Volume by Price
TPO Profile Chart
Numbers Bars
Countdown Timer
(studies which display text only)
[2020-12-18 12:58:43]
Sure, I know the functionality of that study.
You asked for an example of 5-sec MDHG view on a 5-min chart, see attached image.
imagemdhg.png / V - Attached On 2020-12-18 12:55:36 UTC - Size: 164.37 KB - 264 views
[2020-12-18 14:58:01]
Ackin - Posts: 1865
Numbers Bars
Countdown Timer
Volume by Price
Which of the above do you want to duplicate on another chart?
[2020-12-18 16:10:18]
John - SC Support - Posts: 38116
What User907968 suggests and displays, is the right way to do this. Just overlay the 5 minute bars on to the 5 second chart.
[2020-12-18 17:15:16]
Apologies for not providing more details.
See Image 3 attached
I would like the MDHG (5 sec) chart on right to be displayed on the left chart (5minute) which includes studies such as number bars and volume by price that cannot be overlayed.
This way I only need to use 1 chart
Date Time Of Last Edit: 2020-12-18 17:17:19
imageSC.PNG / V - Attached On 2020-12-18 17:16:35 UTC - Size: 355.73 KB - 261 views
[2020-12-18 17:26:25]
That cannot be done.
[2020-12-18 21:18:17]
@ #8
John,
Can this option to make the MDHG set to an independent time period be added to the study at a future date? I believe it would make it more functional on longer time frame charts that are using multiple studies that cannot be overlayed at this point in time and eliminate the need to use Bookmap/Motivewave for heatmap use.
[2020-12-19 11:28:35]
Ackin - Posts: 1865
John - SC Support
I understand exactly what the problem is. This cannot be solved even through a custom chart. You have the entire architecture built on x-axis columns.
What would be possible is to insert it as a dynamic object .... meant at a specific time to insert an "image from another timeframe"
Date Time Of Last Edit: 2020-12-19 11:28:54
[2020-12-21 10:12:02]
@ #10
Thanks for your input Ackin.
Hopefully they see this and can make the change.
[2020-12-21 12:42:02]
Ackin - Posts: 1865
User287830)
If there is no response, I will create something, but not until next month. This year I have a lot of work to do ...
[2020-12-23 10:10:46]
#12
I appreciate that Ackin, how will I know if/when you will able to do this?
[2021-02-11 19:47:35]
Ackin
Have you had a chance to look into the solution you mentioned in #10?
Date Time Of Last Edit: 2021-02-11 19:47:48
[2021-02-11 21:45:46]
Ackin - Posts: 1865
I help a few people in automation in number bars, then I have many requests on my own forum
I can put it on a list of planned studies and look at it (as soon as possible). But currently it is not created.
