Date/Time: Mon, 05 Oct 2026 03:52:18 +0000
Keyboard Shortcut to enable/disable -> Chart Settings >> Alerts
View Count: 1067
| [2020-12-18 08:59:15] |
| User52897 - Posts: 47 |
1. I cannot find any Keyboard Shortcut to disable/enable - > Chart Settings >> Alert. (This refers to the individual chart - not all charts) 2. While I can find an option to mute all Alert Sounds this is not suitable as it mutes Alerts Sounds on a global scale across all charts. 3. I specifically want to disable/enable Alert Sounds to an individual chart via Keyboard Shortcut. If this option is not available in Customize Keyboard Shortcuts, is there a workaround that can be employed ? Please note: the above requirement - clause 3. - can in no way be satisfied using Alert Manager Date Time Of Last Edit: 2020-12-18 13:13:15
| [2020-12-21 05:00:55] |
There is a keyboard shortcut for this. Update to the latest release: Software Download: Fast Update They are located under the Edit menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-21 05:21:46
