Date/Time: Thu, 13 Feb 2025 16:56:01 +0000
Questions about trade service log and padding at the top and bottom of a chart
View Count: 581
[2020-12-18 04:21:19] |
User203781 - Posts: 55 |
1) The trade service log pops up every time one of my stop entries is filled. It is enormously distracting. It is not selected in Global Settings >> General Trade Settings nor in Trade >> Trade Service Log. How do I turn it off? 2) I am using a Flex Renko chart with automatic scale range. The scale padding percentage is set to the default 2.00. The current chart is NQ, with prices around 12,750 and a scale about 50 points from top to bottom. The Compact ToolVal window shows 4 ticks of space at the top of the chart and only 2 at the bottom. Changing the percentage of padding does not alter these margins. Only half of this space is available for stops. When the price is at the chart extremes, stops can be placed only 2 ticks above or 1 tick below. I need at least 4 ticks for stops, sometimes more. What am I doing wrong? And is there a way to set the padding above and below the chart at a constant N ticks with automatic scale range? Thanks. |
[2020-12-18 05:23:39] |
1. Provide the last line from the Trade Service Log when it automatically opens. Refer to: Support Board Posting Information: Providing Lines From Trade Service Log 2. Refer to: Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
