Date/Time: Thu, 13 Feb 2025 17:35:16 +0000
Draw Volume Profile default
View Count: 723
[2020-12-18 01:12:22]
pismo10 - Posts: 161
How do i save Extend value area to end of window as the default? Latest version, worked great for years until today...
thank
Date Time Of Last Edit: 2020-12-18 01:12:39
[2020-12-18 05:18:14]
Follow the instructions here:
Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool
Most importantly create a new Study Collection file that you are using as the default for the particular Tool Configuration for Draw Volume Profile. There is a new format for Study Collections which is required.
Date Time Of Last Edit: 2020-12-18 05:18:38
[2020-12-18 13:43:18]
Great that works.
Next issue is when i add Draw Volume Profile to the chart shortcut menu is brings up a config box instead of jst allowing me to draw a volume profile. If i choose it from Tools>> Draw Volume Profile then it works perfectly but not when added to shortcut menu.
[2020-12-18 15:27:26]
John - SC Support - Posts: 37934
We are not able to reproduce what you are seeing. When we add the option for Draw Volume Profile to the Chart Shortcut Menu and then right-click and select Draw Volume Profile, we can then left-click to set the first point and click again to set the end point and get the profile. If you are doing this a different way, let us know what you are doing.
Can you also give us a screen shot of the window that comes up when select Draw Volume Profile from the Chart Shortcut Menu.
[2020-12-18 15:38:51]
Right click to bring up Menu, then this is what I get..
Date Time Of Last Edit: 2020-12-18 15:39:22
imageDVP1.JPG / V - Attached On 2020-12-18 15:38:17 UTC - Size: 682.45 KB - 268 views
imageDVP2.JPG / V - Attached On 2020-12-18 15:38:25 UTC - Size: 728.49 KB - 275 views
[2020-12-18 16:26:57]
You have added the "Draw Volume Profile Config" option, not the "Draw Volume Profile" option itself. We see that they are both labeled the same, which we will take care of. Just be aware of where you are when you are adding the Chart Shortcut option. If the other items around it have the word "Config" at the end, then you are in the wrong section, you need to go up to the where the Tools themselves are located.
