Date/Time: Thu, 13 Feb 2025 18:56:44 +0000
Can't connect to datafeed
View Count: 672
[2020-12-17 22:49:53] |
pashabenklian - Posts: 8 |
Reading Internal Order ID file. | 2020-12-17 15:24:40.904 Reading Trade Orders file. | 2020-12-17 15:24:41.024 Reading Trade Positions file. | 2020-12-17 15:24:41.025 Reading Account Balance file. | 2020-12-17 15:24:41.026 UDPListener (396). Port 22904 | Listening on UDP port 22904. | 2020-12-17 15:24:41.096 Software version: 1928 32-bit | 2020-12-17 15:24:41.097 Usage end date: 2020-12-31 | 2020-12-17 15:24:41.097 Usage time has ended. Sierra Chart is in Free mode. Features are restricted. | 2020-12-17 15:24:41.097 To purchase usage time, select 'Help >> Add Usage Credit' on the menu. | 2020-12-17 15:24:41.097 * Allow Support for Sierra Chart Data Feeds is enabled. | 2020-12-17 15:24:41.097 Current selected Data/Trading service: SC Futures Order Routing/Data | 2020-12-17 15:24:41.097 Custom symbol settings values: enabled | 2020-12-17 15:24:41.097 Chart Update Interval: 500 | 2020-12-17 15:24:41.097 Intraday Data Storage Time Unit: 0 | 2020-12-17 15:24:41.097 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-12-17 15:24:41.097 2020-12-17 21:24:41 Local computer time | 2020-12-17 15:24:41.101 2020-12-17 20:24:41 Local computer time in UTC | 2020-12-17 15:24:41.101 2020-12-17 15:24:41 Local computer time in SC Time Zone | 2020-12-17 15:24:41.101 2020-12-17 20:24:40 Server time in UTC | 2020-12-17 15:24:41.101 Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-12-17 15:24:41.101 Program path: C:\SierraChart\ | 2020-12-17 15:24:41.101 Data Files path: C:\SierraChart\Data\ | 2020-12-17 15:24:41.101 OS Version Number: 5.1 | 2020-12-17 15:24:41.105 Locale Setting: C | 2020-12-17 15:24:41.106 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-12-17 15:24:41.106 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2020-12-17 15:24:41.142 Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures.dtc.trading. Request ID: 1. | 2020-12-17 15:24:41.142 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Error setting send buffer size to 0. Unknown Windows error code 10022. | 2020-12-17 15:24:41.143 * HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Connecting to IP: 46.4.97.203. | 2020-12-17 15:24:41.143 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-12-17 15:24:41.207 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-12-17 15:24:41.225 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-12-17 15:24:41.225 Received 5 login tokens. | 2020-12-17 15:24:41.251 Symbol settings MD5 received. Request ID: 1. | 2020-12-17 15:24:41.428 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. | 2020-12-17 15:24:41.428 Requested symbol settings for service code sc_futures.dtc.trading. Request ID: 2. Overwrite = on. | 2020-12-17 15:24:41.428 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Error setting send buffer size to 0. Unknown Windows error code 10022. | 2020-12-17 15:24:41.429 * HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Connecting to IP: 46.4.97.203. | 2020-12-17 15:24:41.429 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2020-12-17 15:24:41.501 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2020-12-17 15:24:41.523 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed. | 2020-12-17 15:24:41.523 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. | 2020-12-17 15:24:41.680 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2020-12-17 15:24:41.697 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Closed. | 2020-12-17 15:24:41.697 Symbol settings received. Request ID: 2. | 2020-12-17 15:24:41.795 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Shutdown started. Waiting for graceful close. | 2020-12-17 15:24:42.114 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. | 2020-12-17 15:24:42.131 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Closed. | 2020-12-17 15:24:42.131 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2020-12-17 15:24:43.143 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Error setting send buffer size to 0. Unknown Windows error code 10022. | 2020-12-17 15:24:43.145 * HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2020-12-17 15:24:43.145 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-12-17 15:24:43.549 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-12-17 15:24:43.566 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-12-17 15:24:43.566 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2020-12-17 15:24:44.299 A request for the latest software update has been made. | 2020-12-17 15:24:44.299 * The update is being downloaded in the background. When it is complete, you will be prompted. | 2020-12-17 15:24:44.299 * HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Error setting send buffer size to 0. Unknown Windows error code 10022. | 2020-12-17 15:24:44.300 * HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2020-12-17 15:24:44.300 Download for software update has been redirected. Request ID: 1 -> 2 | 2020-12-17 15:24:44.431 HTTPS connection ID:2 to download2.sierrachart.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2. | 2020-12-17 15:24:44.458 HTTPS connection ID:2 to download2.sierrachart.com:443 for request ID:2 (2) | Error setting send buffer size to 0. Unknown Windows error code 10022. | 2020-12-17 15:24:44.458 * HTTPS connection ID:2 to download2.sierrachart.com:443 for request ID:2 (2) | Connecting to IP: 88.99.0.216. | 2020-12-17 15:24:44.459 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-12-17 15:24:44.683 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-12-17 15:24:44.718 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-12-17 15:24:44.719 Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-12-17 15:24:46.300 * File has been written to: C:\SierraChart\SierraChartFileDownloader.exe. File Size: 6031872 bytes. | 2020-12-17 15:24:46.356 HTTPS connection ID:2 to download2.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2020-12-17 15:24:48.247 HTTPS connection ID:2 to download2.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2020-12-17 15:24:48.273 HTTPS connection ID:2 to download2.sierrachart.com:443 for request ID:2 (2) | Closed. | 2020-12-17 15:24:48.273 Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-12-17 15:24:53.683 * |
[2020-12-17 22:55:38] |
We want you to restart Sierra Chart. And make sure you are logging in with the same Sierra Chart username that you have logged into this Support Board with.
[2020-12-18 21:47:49] |
I've restarted but it's not working still
[2020-12-20 20:10:32] |
We want you to follow the instructions here: Sierra Chart - Software Login Instructions: Forced Login And make sure you log into Sierra Chart with the same username (Account Name) that you have logged into this support board with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-21 14:17:46] |
I saw that Wine isn't supported anymore for versions 2200 and up ?
[2020-12-21 14:32:25] |
How do you come to that conclusion? This is not correct.
[2020-12-21 14:35:04] |
I don't understand, when I download the most recent version of Sierra I can't open it. I have version 1928 and it works fine.
[2020-12-21 14:38:23] |
The newer versions of Sierra Chart only are available with 64-bit support. So make sure you can run a 64-bit version of Sierra Chart. And go into the installation folder of Sierra Chart and run the SierraChart_64.exe file. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-21 14:38:41
