Date/Time: Fri, 25 Sep 2026 23:33:39 +0000
CQG, Rithmic, AMP, Denali - I'm so confused
View Count: 2880
| [2020-12-17 20:43:26] |
| User714262 - Posts: 8 |
Hey, sorry for asking such a stupid question but I really can't find any information either here or on Google that is explaining this 100%. So people are talking about what different data provider they are using and what symbols they then got on Sierrachart. Where do you pick data provider? Currently, I have an account at AMP broker, and on their website, it also says something about CQG and Rithmic but I really don't understand where do I choose which data provider I would like to use, and does it make any difference really? If I subscribe to Denali Exchange Data Feed Service, does that mean I then can pick a data provider? When I go to "Service" in "Data/Trade Service Settings" I can see "Rithmic (trading) but I need a username and password. Thanks for taking time to read such a noob question. |
| [2020-12-17 20:56:44] |
| John - SC Support - Posts: 48028 |
You took the first step and determined that you want to use Sierra Chart. Thank you, we appreciate your business. Next, you would need to determine what Trading provider you want to use with Sierra Chart. With AMP, your options are either CQG or the Sierra Chart Futures Order Routing Service. Where things get a bit weird is that if you choose CQG for your Trading service, you can get data either from CQG or from us (Sierra Chart). But, if you use the Sierra Chart Futures Order Routing Service, then you have to get your data from us (package deal). Let us know if you need help with the next steps of getting setup once you have made your choice. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
