Date/Time: Mon, 14 Sep 2026 02:33:56 +0000
Delayed data
View Count: 1108
[2020-12-17 13:43:13]
Userjacobb - Posts: 2
Hello. I had sierra and data feed through AMP, this spring. Stopped trading since. I just got my sierra chart back going, with the delayed data feed package so I can start to practice and re-familiarize myself with the market. But I open up my Sierra and load the chart figurations I was using from this spring but I can't get it 2 show the data. I changed it and the section to run on the delayed data feed, and I connect to data feed and it shows connected there but nothing happens on my charts. They just stay still from where I left off in the spring.
[2020-12-17 15:46:29]
John - SC Support - Posts: 47854
Have you updated the charts to the most recent instruments?
For example, if you were using ESH20, did you update to the current trading contract - ESH21?
You can use the option Chart >> Perform Futures Symbol Rollover to quickly change the symbol for a chart. Refer to the following:
Chart Menu: Perform Futures Symbol Rollover (Chart menu)
[2020-12-17 18:11:42]
Also make sure the symbols of the charts are correct. Use this Edit menu command:
Edit Menu: Edit >> Translate Symbols To Current Service
[2021-01-07 23:05:28]
I'm sorry I don't notice a follow-up response on here from me, I thought I had thanked you for your help. John that is what it was. I did just Fund my AMP account and get the live data feed, now I can't get any of the charts to do anything since switching from the delayed to the live trading. I did notice if I go to chart settings date range is from 2020-06-17 to 2021-01-05. I can't seem to change it to bring it to today, not sure if that could be an issue. But now that I have live data it seems I have created the problem again of not being able to get anything to load and move.
[2021-01-08 06:48:30]
Make sure the symbols of the charts are correct. Refer to:
Data/Trading Service Connection and Symbol Issues: 1.3. Symbols
