Date/Time: Thu, 13 Feb 2025 17:06:49 +0000
[User Discussion] - reg the limit chase order type for trading on BITmex
View Count: 455
[2020-12-17 11:48:16]
User101680 - Posts: 11
hello,
this is more a comment on the limit chase order type..as i have seen some Q / comments on this order type ppl had in the past
esp for ppl trading products on BITmex via SC that want to use this order type
y have to set the max chase for chase number correct! see pic
max chase for chase number in ticks refers to the number of ticks y want your chase to run untill it stops to chase.
so f.e. if y set it for 50 ticks it will chase 50 ticks and then it will stop chasing if not filled
Date Time Of Last Edit: 2020-12-17 11:52:00
imageSC_chase_.PNG / V - Attached On 2020-12-17 11:46:07 UTC - Size: 15.06 KB - 189 views
