Date/Time: Mon, 21 Apr 2025 23:36:11 +0000
Delete custom study .dll file
View Count: 1046
[2020-12-17 10:09:00] |
User394029 - Posts: 5 |
I have a custom study that I do not use and want to permanently delete. However I do not seem to be able to delete the .dll file that belongs to the custom study, as it keeps reappearing in my Sierra Charts Data folder. How can I permanently remove the custom study with all its files? Thanks, |
[2020-12-17 15:05:23] |
You have a 3rd party study set to automatically download. You can view this information by selecting the link for Enabled Studies and Files Set to Download on the main Control Panel on the Sierra Chart website for your account. Or you can access it directly through this link: https://www.sierrachart.com/UserControlPanel.php?page=EnabledCustomStudies You can disable the download of all files by selecting the button on that page that states Disable File Downloads. But if you just want to stop that one file, then you would need to talk to the developer and have them remove you from their distribution list. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-12 19:23:18] |
User837393 - Posts: 145 |
Hello, I've created a custom dll study (compiled through the server), but I would like to delete it now from the custom study list. Do have any references on how to do so ? Thank you. |
[2025-02-12 21:20:17] |
You just delete the .dll file from your 'data' folder. Or move it somewhere else, if you want to keep it around, but not have it available within Sierra Chart.
