Date/Time: Thu, 13 Feb 2025 17:21:54 +0000
TPO Chart merge Next/ Prior issues
View Count: 437
[2020-12-17 08:13:45] |
Hayden Glenn Barnes - Posts: 7 |
Hi, I seem to have a problem with some of my TPO charts I am not able to currently merge profiles properly as I have been able to in the past. It will allow me to merge with next for 1 maybe 2 profile but then no more and most of the time if I choose next it will merge with previous. Any guidance appreciated. Hayden |
[2020-12-17 08:51:17] |
Update to the current version of Sierra Chart and let us know if you still have an issue . Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
