Date/Time: Fri, 25 Sep 2026 16:16:08 +0000
Highlight/Export single weekday
View Count: 1001
| [2020-12-16 15:33:15] |
| User355493 - Posts: 27 |
Hello, is there a possibility to highlight certain weekdays (e.g. only Wednesdays) by color in the Daily-Bar-Chart (analog to the study "Time-Range Highlight") ? I could not find a function for this. Or is there the possibility to export only certain weekdays when exporting the "Bar Datas" ? So e.g. only Wednesdays of the last 6 months ? Thanks for your Help. Best Regards |
| [2020-12-16 16:40:04] |
| John - SC Support - Posts: 48018 |
You could use the Color Bar Based on Alert Condition and use the following formula for your Alert Condition (for Wednesday): WEEKDAY(BARDATE) = 4 Refer to the information here for Color Bar Based on Alert Condition: Color Bar Based on Alert Condition And refer to the following for the WEEKDAY function: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#WEEKDAY_Function And refer to the following for the BARDATE function: Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
