Date/Time: Thu, 13 Feb 2025 17:33:27 +0000
How to get the history of trading on the russian stock exchange in SCh?
View Count: 646
[2020-12-16 15:18:44] |
User960573 - Posts: 15 |
Hello I want to use the history of trading on the Russian stock exchange in sierra chart. What file format should be used when exporting data from Russian brokers? What data parameters should be specified (volume, time, and so on) so that I can work with data in sierra chart?
[2020-12-16 16:25:21] |
John - SC Support - Posts: 37934 |
Refer to the information here: Exporting and Importing Intraday Data Files: Import and Load Note that Step 3 gives you the link to the Text/CSV Format page which contains the information for the file format. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-16 19:07:25] |
hello again! I downloaded data for three months from the finam broker's website, the downloaded file contains data for three months, but the sierra chart shows only one. I have attached a picture. What could be the error?
Attachment Deleted. |
[2020-12-16 19:18:27] |
What is your Days to Load or Use Date Range set to? Most likely whichever one you are using is not set to display all the data. Refer to the information starting here: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysToLoad For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
