Date/Time: Mon, 25 Nov 2024 15:02:40 +0000
Historical Forex Data Source - Just a quick yes or no really
View Count: 1095
[2014-02-18 14:42:11]
Trint - Posts: 115
Hello SC,
With all the latest changes and updates you're performing recently, I take it you will be keeping the same Forex Historical Data Source (very similar to the respected BarChart data) as it's fitting in very well with a system I have at the moment - I just find forex price confluence with the tools that I use that bit 'tighter' when using it on a longer term basis than other sources.
Thanks.
[2014-02-18 17:54:50]
If you referring to the SC Forex Data (FXCM) service, then this will remain.
