Date/Time: Thu, 13 Feb 2025 17:39:00 +0000
Creating a list of markets
View Count: 494
[2020-12-16 12:38:29]
User377189 - Posts: 203
Please find attached screenshot.
I am trying to create a list of markets from the charts above and show the corresponding ratio study from the chart
I built this using Study summary but if you notice there are:
1.Other columns that i do not need
2.The Chart/symbol name only shows up when i click on the particular row
3.Prefer to customize columns that i want to add such as volume for that instrument
Private File
[2020-12-16 16:06:28]
John - SC Support - Posts: 37934
1. On the Study Summary window select Settings >> Set Quote Fields. Refer to the information here:
Study Summary Window: Settings >> Set Quote Fields
2. This is due to the text color being black, which then blends into the background. The color of the text in the Study Summary is defined by the Chart Text. Therefore, you may want to just change the background color of the Study Summary Window (since your other windows are white with black text). Refer to this setting:
Graphics Settings: Study Summary: Background
3. We do not understand what you are asking about here. Apart from the capabilities discussed in point #1 above, the purpose of the Study Summary is to show a consolidated listing of the studies that are on the charts. If you want something specific, then you would need to add the study to the chart(s) as desired. Refer to the following:
