Date/Time: Thu, 13 Feb 2025 17:00:19 +0000
Text Display Above and Below Bar
View Count: 836
[2020-12-16 05:15:38]
User139520 - Posts: 26
Hi Support team,
I use point and figure chart. I want to display the difference between the high and low of a bar as text with the condition being text on top of "X" and text under "O". I am messing around with the Study Subgraph Above/Below Bar as Text and study Bar Difference. I could only get them to display the text either above or below the bars. Is there a workaround to this?
Thank you for your assistance,
imagePointnFigure.PNG / V - Attached On 2020-12-16 05:09:58 UTC - Size: 396.01 KB - 236 views
[2020-12-16 15:23:03]
John - SC Support - Posts: 37934
There are a number of different ways you could do this, but they all depend upon using 2 instances of a study in order to put one set of data on the top of the Xs and another to put the information below the Os.
Probably the easiest way would be to use 2 copies of the Spreadsheet Study, as this would allow you to easily take the cell row and use that to calculate every other value (you could use a formula like ISEVEN(CELL(row)) ).
