Date/Time: Thu, 13 Feb 2025 21:52:42 +0000
CBOE Russell 2000 Volatility (RVX)
View Count: 943
[2020-12-15 21:07:27] |
User968625 - Posts: 260 |
Hello, I can't find this in SC data which I believe is a CBOE index (this is for Russell 2000 as $VXN is for NQ) Can you help? Thanks |
[2020-12-16 15:06:54] |
Just checked both with a search as well (the Symbols under CBOE page and webpage). nothing there yet. not sure if it takes time. thanks for the amazing help
[2020-12-16 16:16:32] |
John - SC Support - Posts: 37944 |
Sorry, what was Post #2 was inadvertently posted, it was meant to just be a draft for the chief engineer to review the settings prior to pushing them out. He will then update this post to let you know that the Symbol Settings have been updated. We have deleted that post. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-18 09:32:13] |
This symbol is Russell 2000 VIX ($RVX). This is now added. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-21 13:48:49] |
something is wrong with this. I think the dates are wrong. the last date I have is 2-22.
[2020-12-28 12:29:08] |
hello, can you pls update this symbol? there is something wrong
[2020-12-29 02:47:13] |
We have asked our data provider about this. No new data is getting received for it.
[2020-12-29 15:28:32] |
Answer: We do not carry https://www.cboe.com/us/indices/dashboard/rvx/ as this is part of the Russell Index license from CBOE - and we only carry the main Index series license from them.
[2020-12-29 19:16:24] |
ok, thank you.
