Date/Time: Mon, 25 Nov 2024 14:36:46 +0000
Data feed for Sierra with AMP broker
View Count: 1570
[2014-02-18 14:15:18] |
User32127 - Posts: 2 |
I use Sierra chart with IQ feed data. I moved to AMP broker and I would like to use Sierra for trading also. Which data AMP uses (CQG, TNTnet, Rithmic) is comparable with IQ feed regarding the quality? I need tick-by-tick accurate data with orders volumes. Thanks |
[2014-02-18 17:57:17] |
We recommend using the Sierra Chart Real-time and Historical Futures Data Feed: http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
