Date/Time: Tue, 22 Sep 2026 06:46:45 +0000
Object text size problem
View Count: 680
[2020-12-15 15:24:02]
User485193 - Posts: 2
Hello, I have a problem since I changed my PC. All the text sizes are very big so I was in Globals Settings and I reset everything to default, that solved almost all the problems except that when I draw a line or a rectangle for example, the size of the text and the price corresponding to this object is too big. How can I change it? I would like the text to be normal size like the price to the right of the graphic. Thank you so much.
[2020-12-15 15:49:48]
John - SC Support - Posts: 47955
Refer to the following:
Chart Drawing Tools: Changing the Font Size For Text Displayed with Tool Drawings (Global Chart Drawing Font)
