Date/Time: Thu, 13 Feb 2025 16:13:58 +0000
COPIAR GRAFICA CON MISMOS INDICADORES
View Count: 525
[2020-12-15 14:30:04]
User456598 - Posts: 27
Cordila saludo,
quisiera saber como hago para copiar un grafico con mis mismos indicadores y configuraciones pero cambiando el tipo de mercado, es decir cambiar mi grafico de mercado S&P500 al mercado NASDAQ, pero conservando mis indicadores y configuraciones de gracico. Gracias
[2020-12-15 15:32:02]
John - SC Support - Posts: 37933
From Google Translate:
I would like to know how I can copy a chart with my same indicators and settings but changing the market rate, that is, change my S & P500 market chart to the NASDAQ market, but keeping my indicators and chart settings. Thank you
Just duplicate the chart and then change the symbol in Chart >> Chart Settings >> Main Settings >> Symbol.
Refer to the following to duplicate a chart:
Using Chart Templates: Duplicating Charts / Template Charts
And refer to the following to change the symbol of a chart:
Changing the Symbol of a Chart: Changing the Symbol of a Chart or Trade DOM Through Chart Settings
Date Time Of Last Edit: 2020-12-16 08:53:04
