Date/Time: Mon, 25 Nov 2024 14:26:01 +0000
Bad history data
View Count: 1496
[2014-02-18 13:09:10]
User74166 - Posts: 1
I have AMP futures demo with Rithmic datafeed. My intraday data seems to be ok, but history data are weird. Can you help? See attached screenshot of SC. https://www.dropbox.com/s/bea2es45g5irqqg/Screenshot%202014-02-18%2014.08.41.png
Thank you
[2014-02-18 18:02:44]
In the case of Rithmic since there is only 1 Minute Historical data, you will see what you do.
The solution is to use the Sierra Chart Real-time and Historical Futures Data Feed:
http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php
