Date/Time: Thu, 13 Feb 2025 16:15:57 +0000
VWAP
View Count: 642
[2020-12-15 10:10:22]
User152844 - Posts: 6
When using the VWAP. Is it possible to also get a number which indicates how steep the current angle is?
For example: Zero (0), when the VWAP is horizontal and a minus number when pointing downwards and a plus number when pointing upwards?
Given the sizes of the number (negative/positive) one would then get a more precise sense of how bullish or bearish the market is, instead of just visually evaluating the steepness of the VWAP.
Thank you in advance.
Regards Steffen B.
[2020-12-15 15:18:40]
John - SC Support - Posts: 37933
Refer to this study:
Study Angle
