Date/Time: Thu, 13 Feb 2025 17:32:33 +0000
Market Symbols
View Count: 951
[2020-12-15 09:33:45]
Adam Schwartz - Posts: 81
I have been trying to find the page online where SC lists all its market symbols or stats. Such as $MMTH and $MMFI (% of stocks above 50/200 day average). I can't find it anymore. Also nasdaq new highs $HIGQ and new lows $LOWQ
Any link would be appreciated,
[2020-12-15 14:53:31]
John - SC Support - Posts: 37934
Refer to the following:
https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php
Note that there are links at the top of that page that take you to the different groupings (Indices, Forex, Funds, etc.).
[2020-12-15 15:01:48]
I've checked this, but can't find the tickers mentioned in my initial post. Have you got rid of them? I am looking for $MMTH and $MMFI which is % of stocks above 50 and 200 day avergae. Also, $HIGQ which is amount of nasdaq stocks hitting new highs. They don't seem to be on any of those pages, but they used to be.
[2020-12-15 15:03:47]
I am looking for more than the above by the way, but I imagine that if I can locate the page where those symbols are listed, I will find the others I am looking for.
[2020-12-15 15:43:39]
Here is where the Market Statistics symbols are:
Sierra Chart Market Statistics: Symbols
[2020-12-15 15:52:42]
Thanks but this does not answer my question. Maybe it is better if I rephrase it:
Where would I go to find the ticker symbol for the percent of stocks trading above their 20 day moving average?
The links you have provided in both your responses do not answer this question. I know it is out there somewhere as I used to have it, but it seems to have disappeared/relocated.
[2020-12-16 08:04:33]
That page has been removed. Those are Barchart symbols and they can still be used though. You can check the Barchart.com website for the symbols although we are not sure where they are.
You can also perform your own scans for these conditions:
Study/Chart Alerts And Scanning: Scanning for Alert Condition Across Multiple Symbols
Date Time Of Last Edit: 2020-12-16 08:05:24
