Date/Time: Thu, 13 Feb 2025 17:22:44 +0000
[User Discussion] - Multiple Entries with Independent attached orders
View Count: 2713
[2020-12-15 06:50:46] |
User190501 - Posts: 96 |
Hi Support, I use ACSIL system to issue 3 trades at the same time, each has its own directly attached orders -- each limit has its own independent price. Limit 1 Target 1 stop 1 Limit 2 Target 2 stop 2 Limit 3 Target 3 stop 3 When Limit 1 is the only filled contract and the position size is 1, it is exiting at its target Target 1 When the 3 orders are filled and the position quantity is 3 , then the exit of the orders are not matching their attached orders... For example, the nearest entry to the first target is taken out first ... Limit 1 will exit with Target 3 as Target 3 is the nearest to Limit 1 ... Is this an expected behavior ? NO scaling in No Scale out .. Each order has its own attached orders but when all are filled the exit of the filled limits are not associated with its attached orders ... Kindly advise if this is an expected behavior ? For sure attached orders is enabled at the ACSIL. |
[2020-12-15 14:22:56] |
Sawtooth - Posts: 4173 |
You might be interested in these threads: Second trade entry logic ERROR! Moving Stop Loss to Break-Even Automatically While Scaling in. |
[2020-12-15 18:15:07] |
I have attached a chart --- If the order fills and matching are irrelevant to the corresponding attached orders --- My question would be how to inform SC to take out order 1 at target 1 --- order 3 at target 3 ... Note that this is a long trade , so order 1 is filled first and order 3 is filled last .. I have tried to change the various settings under chart settings advanced 3 for open position average price and it has no impact on the execution. |
Attachment Deleted. 2020-12-15 11_48_03-.png / V - Attached On 2020-12-15 18:12:49 UTC - Size: 120.35 KB - 314 views |
