Date/Time: Thu, 13 Feb 2025 16:59:21 +0000
Chart Linking
View Count: 638
[2020-12-14 22:02:49] |
User377189 - Posts: 203 |
I have created and chartbook with 8 charts and have linked the charts for symbol 6A But my trading chart will be M6A Using the same chartbook i wish to change symbol to 6E and that will automatically change all charts to 6E but trading chart i need to change manually for each chart. How can i set the trading symbol to change as per the chart symbol? |
[2020-12-15 14:42:55] |
John - SC Support - Posts: 37934 |
We assume that you are referring to the Trade and Current Quote Symbol. You can link these items in Chart >> Chart Settings >> Advanced Settings 2 >> Chart Linking >> Trade/Quote Symbol. Refer to the information here for Chart Linking: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-15 15:24:41
[2020-12-16 08:02:35] |
You can also set the Trade and Current Quote Symbol globally to be associated with a particular symbol in the Global Symbol Settings: Global Symbol Settings This will go into effect when the symbol of the chart is changed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-16 16:36:09
