Date/Time: Thu, 13 Feb 2025 16:34:38 +0000
Number Bar Calculated Value
View Count: 436
[2020-12-14 17:58:29] |
User985254 - Posts: 1 |
Hello Is there any way to change the order in Number bar Calculated Value? Like changing the position up/down Total volume, Cumulative Delta ,Bar Duration ? |
[2020-12-14 18:16:15] |
John - SC Support - Posts: 37934 |
Use the Subgraph Display Order Input. Refer to the information in this section: Numbers Bars: Numbers Bars Calculated Values Input Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
