Date/Time: Thu, 13 Feb 2025 17:24:48 +0000
Replay DOM Market Depth Quotes
View Count: 1193
[2020-12-14 17:22:20] |
RolandC - Posts: 54 |
I have already made sure that" My Dom and charts all have the same "Days to Load" loaded, which covers the date from which I want to replay. I have also ensured that I am using the same continuous contract settings. I have gone to Global Settings > Symbol Settings and Changed Record Market Depth Data to YES. My time Zone settings are all Global Time Zone settings. Now when I replay the charts and DOM, the Market Depth Limit orders in the DOM are away from the actual price. How do I fix this? |
[2020-12-15 13:16:51] |
Can I have some help with this please
[2020-12-15 19:30:40] |
We are not clearly understanding this. Provide an image of the chart or Trade DOM which shows this, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-15 19:54:00] |
http://www.sierrachart.com/image.php?Image=1608061917438.png
[2020-12-16 08:32:25] |
We see you are using CQG data and we cannot help with that data. We do not provide any technical support for that data. You need to use the Denali Exchange Data Feed for proper support for market depth data including historical market depth data: Denali Exchange Data Feed Although one thing to check is to make sure the session times for the trading DOM cover the full 24 hours: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-16 08:33:19
