Date/Time: Thu, 13 Feb 2025 17:21:36 +0000
tws + sierra chart attached orders problem
View Count: 710
[2020-12-14 17:12:37] |
User46867 - Posts: 2 |
Hi, I have a question about connection of tradework station (Interactive Brokers) and Sierra Chart. I am using sierra chart data feed. When I connect to tws everthing works fine. I am trading thru DOM (clicing right to to DOM) but I have a problem with sending my attached orders together with the original buy/sell order. The only order that I see appearing in TWS is the current buy/sell order but I dont see my stop and profit target being placed in together with it. I used to trade this way few years ago and I always saw my attached orders (stoploss and profit target) being placed to TWS together at the same time. Like this it seems to me that if I place the buy/sell order and my computer got disconected my order will stay in TWS waiting to fill without SL and PT. Can you help me with settings so attached orders are sent together with the buy/sell order? Thank you very Jakub |
[2020-12-14 18:13:15] |
John - SC Support - Posts: 37934 |
Refer to the information here: Interactive Brokers Trading Service: Trading Related Issues For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-14 18:30:46] |
You need to enable this setting: Global Trade Settings Windows: Use Server Side Bracket Orders (if supported) (Global Settings >> General Trade Settings >> General) Please also consider using the Sierra Chart Order Routing Service if you are trading futures: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-16 15:43:29] |
Thank you for your quick reply? Might I ask what would the benefit for me for using Sierra Chart Order Routing Service since? As far as I understand, when the parent order is transmited to TWS together with Bracket order, even when I got disconected or my Sierra Chart freezes or whatever, my orders (parent with bracket) are already in TWS and I am not stuck in the trade without stoploss. Maybe I am missing someting. Please share your thaughts. Thank you very much in advance Jakub |
[2020-12-17 22:28:48] |
We are just providing information about the service and you can make your own judgment. Information about it is here: Sierra Chart / Trading Technologies Futures Order Routing Service: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
