Date/Time: Thu, 13 Feb 2025 16:27:08 +0000
Automated trading - line code to exit a trade at a define time of day?
View Count: 494
[2020-12-14 12:12:05] |
User285018 - Posts: 1 |
Hi, I cannot get sierrachart to exit a position before the end of a pit session. For eample, if I am in a position position but would like to get it closed before the pit closes? thank you |
[2020-12-14 17:33:15] |
John - SC Support - Posts: 37934 |
You could use the Global Profit/Loss Management feature and set the time you want to flatten your trades in the Flatten Positions at Set Time field. Refer to the information here: Global Profit/Loss Management: Flatten Positions at Set Time For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-14 18:32:28] |
If you want to close just one position at a particular time, then use this Trade Window setting: Basic Trading and the Trade Window: A >> Flatten And Cancel at Set Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
