Date/Time: Thu, 13 Feb 2025 16:34:38 +0000
DOM Historical data replay
View Count: 945
[2020-12-13 21:57:56] |
User894573 - Posts: 9 |
Greetings When using the chart replay, orders are not listed on the DOM, how do I correct this? I have enabled historical data under Global Settings -> Symbol setting, but the historical orders do not appear on the DOM (the heat map is working). |
[2020-12-14 05:56:46] |
Refer to the instructions here: Chart Trading and the Chart DOM: Viewing Orders and Trade Position on the Chart / Trade DOM ( we now realize you are probably referring to market depth data, so this is not applicable) And make sure you are doing the replay properly: Replaying Charts: Replaying Trade DOM Windows And refer to: Global Trade Settings Windows: Troubleshooting Market Depth Data Not Displaying in Chart/Trade DOM Columns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-14 05:57:20
