Date/Time: Mon, 21 Sep 2026 22:46:24 +0000
[User Discussion] - Display integer value in one of the subgraphs
View Count: 722
[2020-12-12 08:58:42]
User92573 - Posts: 614
Dear Support/Forum
I'm simply counting Bars e.g. 1 to n and storing the integer value in a (PersistentInt) which then sets the value in Subgraph_count[sc.Index]. As this is a float array I receive conversion integer to float warnings as expected.
The value displayed in the chart at Subgraph_count[sc.Index] using DRAWSTYLE_VALUE_ON_HIGH or DRAWSTYLE_VALUE_ON_LOW again as expected is formatted as per the sc.ValueFormat for the study and not as an integer which I require.
I cannot set sc.ValueFormat = 0; as this impacts the whole study and the other subgraphs require float values.
I've searched the help files and forum but cannot find a solution. Please can you help with this or direct me to a similar example study that solves a similar issue.
Many thanks
PS including sc.ValueFormat = 0; in the (sc.SetDefaults) does not seem to set that value when the study is loaded. Instead it defaults to VALUEFORMAT_INHERITED?
