Date/Time: Thu, 13 Feb 2025 14:18:08 +0000
Loading intraday data for a date range
View Count: 545
[2020-12-12 06:31:15] |
aelagha - Posts: 31 |
I am trying to load ES intraday data for a specific date range (2020-10-01 to 2020-10-30). However, the To field is always greyed no matter what I do. When I set the Numbers of Days to Load, the last several months are loaded to the current date. Also, when I change the Start date, it gets reset to what it was before (what is in the data file, I guess). I have gone through the Chart Settings help (https://www.sierrachart.com/index.php?page=doc/ChartSettings.html&CAID=default), and cannot figure out how to make it work. Thanks |
[2020-12-12 14:06:31] |
Refer to the documentation here for the setting that you need to adjust: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseDateRangeFromTo Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
