Date/Time: Thu, 13 Feb 2025 14:23:03 +0000
Is there a quick way to change the symbol in
View Count: 536
[2020-12-12 05:31:49] |
Shawn J - Posts: 32 |
I've used "Add Additional Symbols" to create the candlesticks. Is there a way to link that study with the chart settings so that all the settings are still in place when searching for a new symbol? I have to search for symbols on the study and then on the chart settings for the candlesticks and number bars to show the same symbol on the chart.
[2020-12-12 14:16:56] |
We are not understanding the question. But there is no linking between the Add Additional Symbol study and the Chart Settings.
