Date/Time: Sat, 12 Sep 2026 08:18:52 +0000
Subscribed to a month of service but didnt know something
View Count: 832
[2020-12-11 23:36:03]
KylieV1618 - Posts: 79
I just subscribed to a month of service ($26USD) today/yesterday.
However, I was fully unaware of the issue with Rithmic data feed.
Since my data feed is Rithmic, I now have no use for my subscription since I can't seem to connect to my account anyways.
Reading Internal Order ID file. | 2020-12-11 21:38:54.656
Reading Trade Orders file. | 2020-12-11 21:38:54.715
Reading Trade Positions file. | 2020-12-11 21:38:54.717
Reading Account Balance file. | 2020-12-11 21:38:54.719
UDPListener (900). Port 22904 | Listening on UDP port 22904. | 2020-12-11 21:38:54.730
Software version: 1983 64-bit | 2020-12-11 21:38:54.731
Usage end date: 2021-01-08 | 2020-12-11 21:38:54.731
Enabled for: Sierra Chart Historical Data Service. | 2020-12-11 21:38:54.731
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-12-11 21:38:54.731
Current selected Data/Trading service: Rithmic Trading | 2020-12-11 21:38:54.731
Custom symbol settings values: enabled | 2020-12-11 21:38:54.731
Chart Update Interval: 10 | 2020-12-11 21:38:54.731
Intraday Data Storage Time Unit: 0 | 2020-12-11 21:38:54.731
Time Zone: +00:00:00 (UTC+00) | 2020-12-11 21:38:54.731
2020-12-11 13:38:54 Local computer time | 2020-12-11 21:38:54.731
2020-12-11 21:38:54 Local computer time in UTC | 2020-12-11 21:38:54.731
2020-12-11 21:38:54 Local computer time in SC Time Zone | 2020-12-11 21:38:54.731
2020-12-11 21:38:55 Server time in UTC | 2020-12-11 21:38:54.731
Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-12-11 21:38:54.731
Program path: C:\SierraChart\ | 2020-12-11 21:38:54.731
Data Files path: C:\SierraChart\Data\ | 2020-12-11 21:38:54.731
OS Version Number: 6.1 | 2020-12-11 21:38:54.731
Locale Setting: C | 2020-12-11 21:38:54.731
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-12-11 21:38:54.732
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2020-12-11 21:38:54.752
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-12-11 21:38:54.768
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-12-11 21:38:54.952
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-12-11 21:38:54.952
Received 5 login tokens. | 2020-12-11 21:38:55.461
Symbol settings MD5 received. Request ID: 1. | 2020-12-11 21:38:55.583
Symbol settings are up-to-date for rithmic.trading. | 2020-12-11 21:38:55.583
Rithmic Trading | Port for executable: 62948 | 2020-12-11 21:39:00.650
Listening socket (680). Port 62948 | Closed. | 2020-12-11 21:39:00.650
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-12-11 21:39:00.651
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:62948. Current folder: C:\SierraChart\Rim | 2020-12-11 21:39:00.663
Rithmic Trading | Bridge process is running. | 2020-12-11 21:39:02.673
Rithmic Trading | Connecting to the server 127.0.0.1. Port 62948 | 2020-12-11 21:39:02.673
DTC Client socket (1) | Creating socket. | 2020-12-11 21:39:02.673
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-12-11 21:39:02.673
Rithmic Trading | Connected to server. | 2020-12-11 21:39:02.673
Rithmic Trading | Starting socket receive thread. | 2020-12-11 21:39:02.673
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-12-11 21:39:02.674
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-12-11 21:39:02.680
Rithmic Trading | Sending logon request message. | 2020-12-11 21:39:02.680
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-12-11 21:39:02.682
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-12-11 21:39:02.683
Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-12-11 21:39:02.683
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-12-11 21:39:03.944
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-12-11 21:39:04.488
Rithmic Trading | Received logon response. | 2020-12-11 21:39:04.488
Rithmic Trading | Server Name: DTC Bridge. | 2020-12-11 21:39:04.488
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-12-11 21:39:04.493
Rithmic Trading | Logon error received from server | 2020-12-11 21:39:04.493
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-11 21:39:04.493
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-11 21:39:04.493
Rithmic Trading | Disconnected. | 2020-12-11 21:39:04.512
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-11 21:39:04.512
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-12-11 21:39:04.512
Rithmic Trading | Port for executable: 62964 | 2020-12-11 21:39:06.512
Listening socket (928). Port 62964 | Closed. | 2020-12-11 21:39:06.512
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-12-11 21:39:06.512
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:62964. Current folder: C:\SierraChart\Rim | 2020-12-11 21:39:06.513
Rithmic Trading | Bridge process is not running! | 2020-12-11 21:39:08.522
Rithmic Trading | Connecting to the server 127.0.0.1. Port 62964 | 2020-12-11 21:39:08.522
DTC Client socket (2) | Creating socket. | 2020-12-11 21:39:08.522
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-12-11 21:39:08.522
DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-12-11 21:39:09.527 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-11 21:39:09.527
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-11 21:39:09.527
DTC Client socket (2) | Closed. | 2020-12-11 21:39:09.527
Rithmic Trading | Disconnected. | 2020-12-11 21:39:09.536
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-11 21:39:09.536
Rithmic Trading | Port for executable: 62968 | 2020-12-11 21:39:11.551
Listening socket (660). Port 62968 | Closed. | 2020-12-11 21:39:11.551
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-12-11 21:39:11.551
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:62968. Current folder: C:\SierraChart\Rim | 2020-12-11 21:39:11.552
Rithmic Trading | Bridge process is not running! | 2020-12-11 21:39:13.561
Rithmic Trading | Connecting to the server 127.0.0.1. Port 62968 | 2020-12-11 21:39:13.561
DTC Client socket (2) | Creating socket. | 2020-12-11 21:39:13.561
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-12-11 21:39:13.561
DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-12-11 21:39:14.562 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-11 21:39:14.562
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-11 21:39:14.562
DTC Client socket (2) | Closed. | 2020-12-11 21:39:14.562
Rithmic Trading | Disconnected. | 2020-12-11 21:39:14.581
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-11 21:39:14.581
Rithmic Trading | Port for executable: 62971 | 2020-12-11 21:39:16.589
Listening socket (660). Port 62971 | Closed. | 2020-12-11 21:39:16.589
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-12-11 21:39:16.590
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:62971. Current folder: C:\SierraChart\Rim | 2020-12-11 21:39:16.591
Rithmic Trading | Bridge process is not running! | 2020-12-11 21:39:18.600
Rithmic Trading | Connecting to the server 127.0.0.1. Port 62971 | 2020-12-11 21:39:18.600
DTC Client socket (2) | Creating socket. | 2020-12-11 21:39:18.600
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-12-11 21:39:18.600
DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-12-11 21:39:19.600 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-11 21:39:19.600
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-11 21:39:19.600
DTC Client socket (2) | Closed. | 2020-12-11 21:39:19.600
Rithmic Trading | Disconnected. | 2020-12-11 21:39:19.616
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-11 21:39:19.616
Rithmic Trading | Port for executable: 62975 | 2020-12-11 21:39:21.630
Listening socket (932). Port 62975 | Closed. | 2020-12-11 21:39:21.630
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-12-11 21:39:21.630
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:62975. Current folder: C:\SierraChart\Rim | 2020-12-11 21:39:21.632
Rithmic Trading | Bridge process is not running! | 2020-12-11 21:39:23.639
Rithmic Trading | Connecting to the server 127.0.0.1. Port 62975 | 2020-12-11 21:39:23.639
DTC Client socket (2) | Creating socket. | 2020-12-11 21:39:23.639
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-12-11 21:39:23.639
DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-12-11 21:39:24.639 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-12-11 21:39:24.639
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-11 21:39:24.639
DTC Client socket (2) | Closed. | 2020-12-11 21:39:24.639
Rithmic Trading | Disconnected. | 2020-12-11 21:39:24.659
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-12-11 21:39:24.659
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-12-11 21:39:25.750
DTC Client socket (1) | Closed. | 2020-12-11 21:39:25.750
[2020-12-12 14:14:43]
The supported Data and Trading services are listed here:
Table of Contents | (Supported Data and Trading Services)
Are you wanting to do live trading? We do have better alternatives to Rithmic. And we do offer a simulated trading service as well.
We can issue a refund and that can be requested here:
https://www.sierrachart.com/usercp.php?page=SupportTickets
Date Time Of Last Edit: 2020-12-12 14:15:19
[2020-12-14 05:17:36]
I signed up for aTrading Evaluator - Delayed account
However, when I try to conenct in Sierra charts, there is no option in the dropdown list for Trading Evaluator - delayed.
Only Trading Evaluator. Which doesnt connect because I dont have a trading evaluator account. Only a delayed one.
How do I connect to the delayed one?
[2020-12-14 05:51:15]
The option is available. Refer to the information here:
Simulated Futures Trading Service: Setup Instructions
Specifically this screenshot:
https://www.sierrachart.com/images/TradeEvaluatorServicesList.png
Be sure to add an account balance:
Simulated Futures Trading Service: Account Balance Adjustments
Date Time Of Last Edit: 2020-12-14 05:52:55
