Date/Time: Fri, 18 Sep 2026 04:12:53 +0000
Different SC accounts in same computer
View Count: 727
[2020-12-11 17:34:45]
JDMontero - Posts: 34
Is it possible to use the SC I have installed in my computer with a different username and password?
For example, if somebody has a SC account username and password, could they use the SC in my computer with their username and use SC the way I have it set up? Or is my account for unique use in my computer?
Thanks.
[2020-12-11 19:17:13]
John - SC Support - Posts: 47930
Someone else could log in on your Sierra Chart and they would have the setup that you have already established. The Chartbooks are not saved on a per user basis, they are just stored on your system.
