Date/Time: Sat, 26 Sep 2026 07:36:48 +0000
[User Discussion] - Verbal Trading Journal
View Count: 1859
[2020-12-11 16:59:07]
User452630 - Posts: 12
HI
This software claims to work with sierra charts. verbaltradingjournal.com does it integrate with the sierra charts charts? I don't actually trade through sierra was wondering if that is required.
[2020-12-13 12:40:13]
binaryduke - Posts: 387
You mean www.verbaljournaltrading.com
It is an add-on study for Sierra Chart, so of course you need Sierra Chart to use it.
[2020-12-14 17:55:20]
okay. My question was if I needed to use the trading functions of sierra charts to use it. I realise that a sierra chart subscription is needed. Do you use it? Is it in the studies section?
[2020-12-14 18:03:52]
I don't understand "if I needed to use the trading functions...". It is a study that is applied to a chart. It is an add-on 'Custom Study' that you purchase from www.verbaljournaltrading.com which then results in it being available to you in Custom Studies.
I am the developer that developed it for www.verbaljournaltrading.com (not my venture).
[2020-12-14 18:48:24]
Thanks for that - I emailed the verbal trading journal people and haven't had a response ( after a week) so was wondering if it was still working. It doesn't require them to be a going concern to work? Doesn't seem as if they are around much. Any input helpful, Cheers
[2020-12-14 20:10:54]
VerbalJournal - Posts: 5
We never received an email concerning your inquiry, but please feel free to send again if you have any questions.
[2020-12-15 09:48:43]
HI
I have emailed you through the company website, can you answer me there please? Thanks
[2021-01-04 16:12:47]
Mattthespaniard - Posts: 42
This Custom Study just stopped working when I updated Sierra chart to version 2215
Message Log says that it needs to be recompiled for this version.
Any help ?
[2021-01-04 17:14:13]
I am not the developer - I didn't buy the program was it useful? Maybe the verbalJournal guy will reply, let me know if it gets fixed.
[2021-01-05 15:23:32]
Mattthespaniard--It works and was re-compiled. However, you have to add it back as a custom study. There have been 2 SC updates that have required many add-ons to recompile over the last 3 months. If you have any other issues please email support@verbaljournatrading.com and we can look up your account.
[2021-01-05 17:53:31]
No, it doesn't work despite having added it back. Same message "Verbal Journal needs to be recompiled for this version of Sierra Chart. | 2021-01-05 18:46:03.233 *"
Also, the functionality issues I have frequently pointed out by email are still unresolved.
[2021-01-07 01:17:51]
I'm sorry I forgot to mention above that you have to delete your previous VJ dll file(s). Then re-start SC.
1. Remove all previous Verbal Journal .dll files from Sierra Chart /data folder (dll files only)
2. We now only include the 64-bit version. Sierra Chart have stopped distributing the 32-bit app.
3. Add study back in from Custom Studies. Version number of the study is 110 (on Study Settings)
