Date/Time: Thu, 13 Feb 2025 16:24:53 +0000
Open of Range Bar Incorrect with Range Met in Ticks. Please Fix.
View Count: 665
[2020-12-10 19:28:31] |
cmet - Posts: 606 |
I have been starting to notice this more and more when using Range Per Bar - New Bar on Range Met (in ticks). The open is placed at the low of the next bar after an up bar or the top of the next bar after a down bar. This shouldn't be possible with this bar type. Just trying to figure out what's going on since I use these bars a lot. Image attached for reference. |
[2020-12-13 00:25:45] |
cmet - Posts: 606 |
Can this please be looked at. Setups I have that rely on accurate bar opens are now getting missed because of inaccurate plotting of the bar open. Here's another example. One of many. Bar Type: Range Per Bar - New Bar on Range Met (in ticks). Timestamp for image: Thursday 12/10/2020, 10:50:41 PST. Chart: 10 Tick Range. 20 Days of price data. New Bar At Session Start unchecked. I see this is 6 and 8 Tick Range charts as well. |
[2020-12-13 03:58:52] |
There definitely is not a problem here. We have updated the description here: Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Range Per Bar - New Bar on Range Met (in ticks) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-13 03:58:53] |
[2020-12-13 04:34:12] |
cmet - Posts: 606 |
Been using these bars a long time and have never seen this issue until recently. Why would anyone want to plot price on bars where the open sometimes repaints? The open=close version creates completely different study calculations but I guess that's what you're pointing me to. |
[2020-12-13 19:00:31] |
Nothing has changed in regard to this Bar Period Type and there is not any problem. It works correctly and according to specifications. It is only the case when a new underlying Intraday file record or trade, in the case of tick by tick data, is being added to a chart bar and the range of the last bar is equal to the range setting, is then a new bar started at that time. The trade that extends the bar range to the specified range, will not in and of itself start a new bar. Only the next trade will.
We do not know what this means, and there is no problem like this: where the open sometimes repaints?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-13 19:01:18
