Date/Time: Thu, 13 Feb 2025 14:38:58 +0000
Historical Data Error
View Count: 712
[2020-12-10 14:35:34] |
User907968 - Posts: 826 |
Some strange behaviour from historical data server today, see below, this is appearing for a number of CME symbols on the Denali feed. Added historical Daily data request for NQZ20-CME to the queue. | 2020-12-10 08:28:53.393
Triggering next historical data download in queue. | 2020-12-10 08:28:53.393 HD Request # 11 | Downloading Historical Daily chart data for NQZ20-CME. Starting date: 2020-12-08. Service: scdataallservices | 2020-12-10 08:28:53.394 HD Request # 11 | Requesting historical Daily data for NQZ20 starting at 2020-12-07. SC External HD service. | 2020-12-10 08:28:53.394 HD Request # 11 | Response is invalid and contains a webpage: <html><head><title>504 Gateway Time-out</title></head><body bgcolor="white"><center><h1>504 Gateway Time-out</h1></center><hr><center>nginx/1.13.6</center></body></html> | 2020-12-10 08:29:53.552 HD Request # 11 | Bytes received: 183 | 2020-12-10 08:29:53.552 HD Request # 11 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQZ20-CME | 2020-12-10 08:29:53.552 HD Request # 11 | Completion time: 1m | 2020-12-10 08:29:53.552 HD Request # 11 | Daily data download complete for NQZ20-CME. Unique request ID: 11 | 2020-12-10 08:29:53.552 Removing historical data download ID 11. | 2020-12-10 08:29:53.552 |
[2020-12-10 17:14:35] |
John - SC Support - Posts: 37916 |
We will look into this. It does not appear to be affecting the actual download of the historical data, so it can be ignored.
[2020-12-10 17:28:31] |
It definitely is affecting the download, historical daily data is missing and not being filled in. EDIT: Ok, so I should have said wasn't being filled in, tried delete and re-download again and no more error in msg log + data is filled in. I guess it is resolved. Thanks. Date Time Of Last Edit: 2020-12-10 17:32:14
[2020-12-10 18:28:43] |
Refer to: Barchart Data Provider Network Problems and Issues Caused Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
