Date/Time: Thu, 13 Feb 2025 14:15:28 +0000
*please fix* - Late prints in sim mode always close open positions
View Count: 502
[2020-12-10 13:02:35] |
HeyUgly - Posts: 251 |
hello everyday i encounter this, late prints in premarket when testing strategies etc, always close open positions can you guys see what you can do for this? its really annoying quirk, happened 3x this morning thank you! |
[2020-12-11 08:56:02] |
The problem about this is that we already used two layers of filtering and we are very hesitant to be adding additional filtering and then removing these out of range values, which are actually valid trades, which then starts affecting the volume. Nevertheless we are going to think about a solution. Please give us a little time to work out a solution here. Maybe we could add some filter to prevent trading activity during non-regular trading hours from filling simulated orders. If we are going to filter the data we have to identify the particular Sale Conditions causing these out of range values which is really quite involved. Too often, in our prior analysis of things like this, we have made mistakes since these Sale Conditions are not so well understood by us. And that is what we want to avoid. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-11 13:08:31] |
all good thank you for being aware of it!
