Date/Time: Thu, 13 Feb 2025 14:10:05 +0000
Why is text tool entering A^£ (that's carrot over the A) when I enter the £ characte
View Count: 522
[2020-12-10 11:43:26] |
User92573 - Posts: 544 |
Hi Support / forum. Why is my text tool entering A^£ (that's a carrot over the A) when I simply enter the £ character followed by a number? When I delete it in modify, it reappears once saved. All settings keyboard etc are UK. Many thanks |
[2020-12-10 15:32:38] |
John - SC Support - Posts: 37916 |
We have been doing some work on the character encoding in order to support a larger array of characters. Refer to the following Support Board Post on this subject: Technical Notice: Extended/Unicode/Wide Character Support in Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
