Date/Time: Thu, 13 Feb 2025 13:24:39 +0000
Chart session settings not following local time changes - Arizona
View Count: 464
[2020-12-09 21:30:43] |
User443178 - Posts: 16 |
Hi, Arizona does not follow the change to DST, it stays MST all year 'round. When the rest of the country changed from daylight savings to standard, my charts which have some indicators about the prior session close started to mark the price an hour earlier than the actual price. When using sim, the DPL would reset at that time as well. Do I possibly have something set wrong, or ?? I applied the "Use Global Settings" to each of the charts which I thought I did when I set the charts up. Will I need to again select that button when the US returns to DST? |
[2020-12-09 22:11:35] |
John - SC Support - Posts: 37916 |
Refer to the information here: Time Zone Setting: Resolving Differences with the Transition To/From Daylight Savings Time in Different Time Zones For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
