Date/Time: Thu, 13 Feb 2025 13:09:23 +0000
Overlay not working properly
View Count: 594
[2020-12-09 17:51:23] |
User837393 - Posts: 141 |
Hello, I have a renko chart and I have a 1 min chart. On the 1 min chart I have a define crossover strategy whitch is built into a spreadsheet. It outputs a label on the main chart of the 1 min chart where the crossover conditions are met. What is the best way to overlay the output of the 1 min chart strategy onto the Renko chart. Price/Study overlay seems to only work partialy. Some output are displayed some are not, while on the 1 min chart all the outputs are perfectly displayed as per the crossfromabove and crossfrombellow formulas... I guess the issue is the difference time scale that is different. But I'm ok with the nearest match. How should do this ? The crossover occurs where there is a "1" http://www.sierrachart.com/image.php?Image=160754328741.png http://www.sierrachart.com/image.php?Image=1607543365378.png As I said it works well on the 1 min charts, but I just can't overlay the effet over the Renko chart... Best regards, Date Time Of Last Edit: 2020-12-09 19:50:52
