Date/Time: Sat, 12 Sep 2026 20:18:57 +0000
Quik to SCH
View Count: 733
| [2020-12-09 16:48:11] |
| User960573 - Posts: 15 |
Hello, I am trying to transfer data from the QUIK trading terminal to the Sierra Chart. This is a Russian platform. Sierra Chart finds the data file but cannot read it. I contacted QUIK support. They asked me in what format the data should be supplied to the Sierra Chart. Can you tell me?
| [2020-12-09 17:18:09] |
| John - SC Support - Posts: 47854 |
Refer to the information here: Text/CSV Data Format If they are interested, they can also look into creating a connection using the DTC protocol. Refer to the information here: DTC Protocol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
