Date/Time: Thu, 13 Feb 2025 13:39:08 +0000
Uopdated to current version 2207
View Count: 567
[2020-12-09 16:00:23]
User900780 - Posts: 1
updated to current version 2207 and my chartbooks did transfer over, getting some type of error message when launching current version, still have the old version on my computer with chartbooks saved, but not transferring over, would appreciate a solution.
[2020-12-09 19:45:44]
Do you see the chartbooks listed in File >> Open Chartbook?
You do have multiple installations of Sierra Chart. So they each are going to have their own Chartbooks.
If you are missing Chartbooks, search your system for them. They have a CHT file extension. Refer to:
Missing Files After Upgrading Software
