Date/Time: Mon, 25 Nov 2024 18:25:03 +0000
Comment activer les données en réel ?
View Count: 1041
[2020-12-09 15:21:00]
User594222 - Posts: 1
Avez-vous un tuto simple pour l'activation des données en temps réel. Sur votre site je ne m'y retrouve pas
Merci
[2020-12-09 15:44:26]
John - SC Support - Posts: 36260
From Google Translate:
Do you have a simple tutorial for real-time data activation. I can't find myself on your site
Thank you
Yes, but it depends on what data you need. Start by going to the page in the following link. This gives the overview of the Real-Time Data Feeds from Sierra Chart. From there, you will determine which data feed you need based on the source data (Denali Exchange Data Feed for the CME Group or the Sierra Chart Exchange Data Feed for everything else). There are links on this page to the pages for each data feed. On each page are Setup Instructions for the data feed.
Real-Time Exchange Data Feeds Available From Sierra Chart
[2020-12-09 19:40:16]
Also refer to this page:
Getting Started, Opening Charts and Basic Trading
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on.
If you require real-time futures data, then refer to:
https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php
Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data.
[2024-02-07 19:25:00]
rfitai450 - Posts: 1
bonjour , je suis en mode trial, j'aimerais savoir si je peu activer les real data ou seulement delayed data . Merci , Robert
[2024-02-07 23:05:11]
hello, I am in trial mode, I would like to know if I can activate real data or only delayed data.
While on a Trial, you can only get Delayed Streaming Data for the CME Group, EUREX, CFE, and U.S. Equities. But you do have access to real time data for FOREX, CFD, Crypto Currencies, and Market Statistics.
