Date/Time: Thu, 19 Sep 2024 16:31:01 +0000
Time and sales && market depth
View Count: 1457
[2014-02-17 17:02:33] |
User91014 - Posts: 1 |
i have a problem in time and sales window, where ask size and bid size and volume are all equal == 1, i.e the real size doesn't appear. the same for market depth bid size = ask size = 1 , and only one level appears . Note: i am subscribed to package # 3, so i am afraid that it doesn't support time and sales and market depth services |
[2014-02-17 17:02:58] |
This will be true in the case of when using the Sierra Chart Forex/CFD Data service which uses FXCM data.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-17 17:03:20
[2014-02-26 14:48:40] |
bwalks123 - Posts: 122 |
So does the Time and Sales not work for forex? What happens when you combine combine same price and time feature will the size increase?
[2014-02-26 18:03:59] |
Time and Sales does work with Forex. What specific "size" are you referring to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-27 00:04:42] |
I pulled up a EURUSD-bidask chart and when i added a time and sales window all i was getting were single lots, even when i had the combined the same time and price feature enabled? Should I be using the EURUSD symbol or EURUSD-bidask symbol when utilizing time and sales or cumulative delta? thx
[2014-02-27 00:23:43] |
This would actually make sense because in the case of the Forex data feed you will never end up with two prices that are exactly the same side by side. For Cumulative Delta use EURUSD. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-27 01:03:30] |
Thank you as switching to EURUSD pulled up the cumulative delta data i was looking for. So forex Time and Sales will only produce "1" on the volume tab? Is there a setting to change where volume is represented in 10k or 100k forex lot sizes? |
[2014-02-27 01:04:51] |
There is no setting like this. Unless you use the Volume Multiplier setting in Chart >> Chart Settings for the chart volume data itself. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-27 01:05:23
