Date/Time: Thu, 13 Feb 2025 13:35:06 +0000
Live trading on BitMEX is only pssible when connecting on BitMEX Trading Direct
View Count: 523
[2020-12-09 14:39:08] |
Ticksniper - Posts: 7 |
Hi, Live trading on BitMEX is only pssible when connecting on BitMEX Trading Direct not when the Connection feed is set to SC Data - All services. Coudl you please help me ? Kind regards, David. |
[2020-12-09 15:36:51] |
John - SC Support - Posts: 37916 |
Yes, this is correct. You can only trade BitMEX when your service is set to "BitMEX Trading Direct". Therefore we do not understand the question.
[2020-12-09 16:02:10] |
I would like to be able to trade multiple instruments from other markets, like NQ, ZB while trading BitMEX as well. Hence, how this multiple data feeds can be aggregated at once. Thank you. David. |
[2020-12-09 16:17:15] |
They cannot be aggregated in the way you want. The easiest solution is to have a second installation of Sierra Chart that you use for trading the other markets while you use the primary installation for BitMEX. Refer to the information here: Using Multiple Data and Trading Services at the Same Time For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-09 16:27:46] |
Thank you. That is clear now. We can close the ticket. Have a nice day. David.
