Date/Time: Thu, 13 Feb 2025 13:13:48 +0000
Control Button Colors
View Count: 1209
[2020-12-09 13:34:22] |
SierraTraders - Posts: 69 |
Is it possible to setup the Sim/mode - Live/mode control button to show backgrounds (Sim/Red) - (Live/Green) Also same use for the Auto Trading Buttons Enable/Green Disable/Red Ref: Global Settings / Graphics Settings / Colors and Width / Control Bar: Enable-Disable Text/Background (When using Text/Background either is selected it changes all buttons is it possible to change only selected buttons) When properties is selected there is an option for one color..... not shore if there is any other options Ref: Control Bar Commands / Control Bar Button Properties |
[2020-12-09 19:28:18] |
You can certainly change the background color of individual Control Bar buttons: Control Bar: Control Bar Button Properties You can also use this ACSIL function to control it programmatically: sc.SetCustomStudyControlBarButtonColor Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-09 19:29:24
[2020-12-09 21:11:56] |
So we understand this correctly One Control Button can be colored Enabled(Red) Disabled(Green) Control Bar: button default background is selected it colors all buttons backgrounds Properties only has one option for colors Maybe just over looking something just not sure what Thank You For Your Help |
[2020-12-09 22:07:22] |
John - SC Support - Posts: 37916 |
You can have different background colors if you program it yourself using ACSIL and using the above-referenced function. Otherwise, there is no option through the user interface to setup different colors for active versus inactive control bar buttons. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
