Date/Time: Fri, 25 Sep 2026 23:10:42 +0000
[User Discussion] - sc.GetOHLCOfTimePeriod Help
View Count: 1808
[2020-12-09 11:54:51]
User820318 - Posts: 40
I am trying to calculate the median price over a time window each day (on intraday chart) are draw that value as a level using a subgraph. I have tried using the
sc.GetOHLCOfTimePeriod()
function to get the High and Low over the interval to then pass to calculation of the median. Below is the code I am using. Unfortunately this simply returns a zero for OpenLevel subgraph. Can anyone point out what I am doing wrong here?
Thanks in advance for any help.
SCDLLName("MedPriceAtTime")
SCSFExport scsf_MedPriceAtTime(SCStudyInterfaceRef sc)
// Inputs
  SCInputRef Start = sc.Input[0];
  SCInputRef End = sc.Input[1];
  // Outputs
SCSubgraphRef OpenLevel = sc.Subgraph[0];
if (sc.SetDefaults) {
    sc.StudyVersion = 20201209;
sc.GraphName = "Median Price At Time";
sc.AutoLoop = 1; //Automatic looping is enabled.
sc.GraphRegion = 0;
OpenLevel.Name = "MedPrice";
OpenLevel.DrawStyle = DRAWSTYLE_DASH;
OpenLevel.PrimaryColor = RGB(255, 182, 193);
OpenLevel.DrawZeros = 0;
    OpenLevel.LineWidth = 2;
    OpenLevel.LineLabel = LL_DISPLAY_NAME | LL_NAME_ALIGN_CENTER | LL_NAME_ALIGN_FAR_RIGHT;
Start.Name = "Start Time";
Start.SetTime(HMS_TIME(5, 30, 0));
    End.Name = "End Time";
End.SetTime(HMS_TIME(7, 30, 0));
return;
// Section 2 - Do data processing here
  // Declare variables
  float OpenTP;
  float HighTP;
  float LowTP;
  float CloseTP;
  float NextOpenTP;
  SCDateTime StartTime = Start.GetTime();
  SCDateTime EndTime = End.GetTime();
  // Get OHLC values over time period
  sc.GetOHLCOfTimePeriod(StartTime, EndTime, OpenTP, HighTP, LowTP, CloseTP, NextOpenTP) ;
  // calculate Median
OpenLevel[sc.Index] = (HighTP + LowTP) / 2;
Date Time Of Last Edit: 2020-12-09 13:19:10
[2020-12-09 14:57:01]
User907968 - Posts: 884
Your SCDateTime variables have no date part set, only time.
You could try, for example -
SCDateTime StartTime = sc.BaseDateTimeIn[sc.Index];
StartTime.SetTime(Start.GetTime());
[2020-12-09 15:11:33]
Thank you for the suggestion. That worked. really appreciate it.
