Date/Time: Thu, 13 Feb 2025 13:16:15 +0000
ES options buying calls and put
View Count: 535
[2020-12-09 04:49:42]
User425160 - Posts: 15
Hello
I am currently trading ES futures using AMP futures with CQG.
I am looking to trade ES options using Sierra Chart.
Does Sierra Chart support ES options?
I asked AMP and they said they allow only buy side does this mean I can only buy calls and put?
[2020-12-09 19:36:21]
Yes options trading is supported. Here are the instructions for accessing option symbols:
Real-Time Exchange Data Feeds Available From Sierra Chart: Futures Options
This method can also be used with CQG.
This does not depend upon Sierra Chart but your broker.
